8. Technical Specifications ​
Robot TypeUFACTORY 850
Robot Weight20KG(body only)
Maximum Payload5kg
Cartesian RangeX: ±850mm, Y: ±850mm, Z: -400~1214mm, Roll/Pitch/Yaw: ±180°
Joint RangeJ1~J6 (±360°, ±132°, -242~3.5°, ±360°, ±124°, ±360°)
Maximum Speed of End-Effector1m/s
Maximum Joint Speed180°/s
Repeatability±0.02mm
Ambient Temperature Range0-50℃
Power ConsumptionTypical 240W, Max 1000W, 500W Power is recommended.
Input Power Supply48V DC, 20.8A
ISO Class Cleanroom5
Mounting WayAny Direction
MaterialsAluminium, Carbon Fiber
FootprintØ 190mm
End FlangeDIN ISO 9409-1-50-4-M6(M6*6)
Robotic Arm Communication ProtocolPrivate TCP(custom)
End Effector Communication ProtocolModbus TCP
ProgrammingUFACTORY Studio, Python/C++/ROS
Joint Rotating Direction
AC ControllerDC Controller
Input100-240V AC 50/60 Hz48-72V DC
Output48V DC 1000Wmax48V DC 960Wmax
Communication ProtocolPrivate TCP(custom)Private TCP(custom)
Communication MethodEthernetEthernet
I/O Interface8×CI+8×DI(Digital In) 8×CO+8×DO(Digital Out)
2×AI(Analog In) 2×AO(Analog Out)
1×RS-485 Master
1×RS-485 Master
Weight4.8kg2.8kg
Dimension(L×W×H)345×135×101mm262×160×76mm
Gripper G2(AG1200)
Nominal Supply Voltage24V DCAbsolute Maximum Supply Voltage28V DC
Quiescent Power (Minimum Power Consumption)1WPayload5kg
Weight800gClamping Force10-50N
Working Range84±1mmSpeed15-225mm/s
Finger TypeReplaceableCycle Life>2,000,000 cycles
Communication MethodRS485Communication ProtocolModbus RTU
Programmable Gripping ParametersPosition, Speed, ForceFeedbackPosition
Protection RatingIP40Operating Temperature50℃
Vacuum Gripper(AS1200)
Rated Supply Voltage24V DCAbsolute Maximum Supply Voltage28V DC
Vacuum-55kPaVacuum Flow (L/min)>4L/min
Weight610gDimensions (L×W×H)122.5×91.6×75 mm
Payload≤5kgNoise Level(30cm away)<60dB
Quiescent Current(mA)20mAPeak Current(mA)500mA
Communication ModeDigital IOState IndicatorPower State, Working State
FeedbackAir Pressure(Low or Normal)
